All of the parts needed to make your mechanical kit to a full kit. DOESNOTINCLUDE the spindle and tools. This does not include the Power Pigtail (30313-01) — Connector/Adaptor: 5.5 mm x 2.5 mm Barrel Male Plug. See http://www.shapeoko.com/wiki/index.php/Parts#Electronics for further details.
Please note that this does not include the Power Pigtail (30313-01) — Connector/Adaptor: 5.5 mm x 2.5 mm Barrel Male Plug. See http://www.shapeoko.com/wiki/index.php/Parts#Electronics for further details.
Please note that this does not include the Power Pigtail (30313-01) -- Connector/Adaptor: 5.5 mm x 2.5 mm Barrel Male Plug. See http://www.shapeoko.com/wiki/index.php/Parts#Electronics for further details
William Adams
I thought that the shapeoko 2 is dual drive by default, only see 3 Aluminum GT2 Pulleys,etc.
Manuel Caceres
Never mind. For some reason i thought you needed 4, I am wrong. 2 for dual y and 1 for x.
disregard my comment.
Manuel Caceres
The GShield is no longer available for purchase?
Mike Eubank
Hey Mike,
The gshield is temporarly out of stock.
Sam Alaimo
Thank you so much. I had ordered the mechanical kit thinking I would order the electronics later, however I was so confused with what to get. Then I stumbled upon your list and bought it immediately. Thank you so so so so much!
Bennett Sampson
Buenos días soy de lima - Perú quisiera saber como puedo hacer para comprar todo el kit y sobre la programación del arduino ya viene programado disculpas por que mi comentario esta en español le agradecería su respuesta
richard alexander salvador natividad
i know i'm late but i'd like to build this, where can i get a replacement or an alternative to the cnc milling kit,since it's no longer available, the x-care is too expensive for me.
Brandon St.Rose
@brandon, your best bet will be to contact the "customer success team":https://inventables.desk.com/ or talk to the public on the "forum.":https://discuss.inventables.com/
Sam Alaimo
Is this all I have to purchase to build this? Also does it come with instructions?
Marcus
I purchased a full kits of Shapeoko2 in 2014. Now I need to use different PC to control it but I for got where I can download the software to control it. Could you please send me the link?
Jing Lin
William Adams
Sam Alaimo
Manuel Caceres
Manuel Caceres
Mike Eubank
Sam Alaimo
Bennett Sampson
Andrew Ryan john
Brandon St.Rose
Sam Alaimo
Marcus
Jing Lin
