Arduino Uno
Microcontroller
Arduino Uno
Price Part Number Description Grbl Firmware Installed
$32.99 Arduino Uno w/ Grbl CNC 1.0c Yes
The Arduino Uno is a microcontroller board based on the ATmega328 (datasheet). It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz ceramic resonator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started.
The Uno differs from all preceding boards in that it does not use the FTDI USB-to-serial driver chip. Instead, it features the Atmega16U2 (Atmega8U2 up to version R2) programmed as a USB-to-serial converter.
“Uno” means one in Italian and is named to mark the upcoming release of Arduino 1.0. The Uno and version 1.0 will be the reference versions of Arduino, moving forward. The Uno is the latest in a series of USB Arduino boards, and the reference model for the Arduino platform.
Grbl is an open source CNC program used by many machines including the Shapeoko, Shapeoko 2 and X-Carve. Details about the version installed can be found here.
Inventables is a strong supporter of open source software and hardware. In addition to our corporate support to the grbl project, we also pay a royalty for every installation of grbl we sell. This applies to machines and controllers. Here is more information on the grbl project
Description
Uno
Accessories
