One of the best upgrades for the Shapeoko is to use a spindle instead of the rotary tool that many start with. The 300 Watt Quiet Cut Spindle from Inventables works great with the Shapeoko desktop CNC. It is a great upgrade for many other DIYCNC router designs as well.
Can you panel mount the pot for the speed control? I want to make a box to put all these electronics in.
Paul Kaplan
I don't have the pot with me, I gave it to Bart last night but I think it has a threaded shaft to mount it to a panel. I don't remember if it had nuts and washers on it.
David Ditzler
Hi David, i am new in cnc router build. I was just wondering where did the 24v going to the gShield came from?
Al Marquez
We sell the 24VDC power supply at Inventables too.
https://www.inventables.com/technologies/24v-power-supply-90w
David Ditzler
Hi David, the relay is only rated for 30VDC according to the Inventables page, yet you are using 48VDC. Did the relay operate fine with this higher voltage? Were you able to use the spindle at full speed?
Mike Jones
I purchased this kit and decided not to connect to the arduino and just manually turn it on and off. What additional parts will i need to do this and do you have instructions? Thanks.
Kristen Bruno
Kristen - You can wire the spindle directly to the speed controller. Use the two motor wires and connect them to the motor out terminal on the speed controller. Then wire up the 48VDC into the power in terminal. Use the dial on speed controller for speed & start/stop.
David Ditzler
Kristen - you won't need a on/off switch to start and stop the spindle you can just use the potentiometer (green and black knob). When you aren't using it you can turn off the whole system by using a power strip to turn off the power supplies.
David Ditzler
The relay is rated for 30V DC and the power supply is 48V DC.. Wouldn't that be an issue going over specified tolerance?
Tanveer Ahmed
Paul Kaplan
David Ditzler
Al Marquez
David Ditzler
Mike Jones
John Chapman
Kristen Bruno
David Ditzler
Kristen Bruno
David Ditzler
Tanveer Ahmed
