Mon - Fri: 9am - 6pm CT
Sun: 12pm - 4pm CT
Support: 312-775-7009
Gold and Clear Reverse Laserable Acrylic Sheet
Laserable acrylic sheets that can be engraved from the back
Price Part Number Dimensions Thickness Thickness Tolerance
$17.97 8 in × 12 in 1/8 in ± .005 in
While traditional two-color acrylic is engraved on the top, these sheets are designed to be engraved from the back. This exposes the bottom color while keeping the top of the sheet smooth and flat. Please remember to mirror your text or image before engraving so that it is right side up once the sheet is flipped.
This sheet is clear on top and gold on the back. The gold side should be engraved for best results.
Cutting depth
0.003"
Cut tolerance
+/- 1/4"
Color
Gold
Effect
2 color reverse engravable
Opacity
Opaque
Surface Finish
Matte non-reflective
Files & Attachments
MSDS
Metallic Reverse Laserable Acrylic MSDS.pdf
Add your project
