Brushed Gold on Blue Laserable Acrylic Sheet
Laser engrave blue markings on a brushed gold surface
  • Brushed Gold on Blue Laserable Acrylic Sheet
$35.66 12 in × 24 in 0.022 in
$11.29 8 in × 12 in 1/16 in
This acrylic works great both in a laser cutter and on a 3D carver like the X-Carve or Carvey.
Please note these are intended as ‘a starting point’ and adjustments in 5% increments may be needed to achieve optimal results. When engraving & cutting the .022” thickness a 10-15% reduction in power would certainly be reasonable.
Color
Blue
Color
Gold
Effect
2 color
Effect
Metallic
Opacity
Opaque
Surface Finish
Metallic
Thickness Tolerance
± .003 in
Files & Attachments
MSDS
1:16" Metallic Laserable Acrylic MSDS.pdf
Add your project
