DIY CS Go Plywood Prop Karambit – X-Carve
more info here: https://youtu.be/syauCt7vHdw
blog post: https://dali-lomo.blogspot.com/2017/05/how-to-make-wooden-karambit-from-cs-go.html
The author’s moral rights;
Dali Lomo
