Change the numbers, font spacing etc. until you have a design that you like. Select all of your design elements and make them “outline” cuts. For the wood piece we’ll be specifying an "inside’ path, that way we won’t see these cuts in the final piece. When you’re ready click “Carve” and follow Easel’s instructions.
Open the second workpiece and customize the design to match what you made in on the first workpiece. We’re using an “outside outline” cut for this material. Double check that all of your design elements are the same size they were for the wood. When you’re ready to go click “Carve” and follow Easel’s instructions.
All of the pieces are cut and we’re ready to assemble. Put the acrylic pieces on the wood without glue first just to check the fit. You should be able to cover up all of the lines you carved into the wood. When you feel confident in your layout you can start gluing the pieces together. Try to use a light bead of glue on the inside of your numbers, this way any excess glue will find its way into the trough you made in the wood. The glue should set in a few minutes.
Dan Brown
Patrick Dunne
Chris Gray
Bruneau Fanor
Bruneau Fanor
