Setup cut lists for table saws in Easel Cabinetmaker
In the world of cabinetmaking, tradition and technology often cross paths. While CNC machines have brought a futuristic touch to the industry, traditional power tools like saws continue to be a favorite for many. Recognizing the integral role these tools play, Easel Cabinetmaker has bridged the gap between the old and new with its latest feature: Cut Lists for Saws.
Cut Lists: Tailored for Traditionalists
At the heart of every cabinet lies a meticulous design and a precise cut. Whether you're armed with the latest CNC machine or a trusty saw, the end goal remains consistent: achieving perfection in every cut. Easel Cabinetmaker's new feature caters specifically to those who rely on table, track, or panel saws for their projects.
With just a few clicks, users can now generate a comprehensive and printable cut list. This list will guide you through each step, ensuring that every piece of wood is utilized optimally and your design comes together flawlessly.  To see how it works get started for free in Easel Cabinetmaker.
Benefits of Using Cut Lists for Saws
  1. Optimized Material Use: The cut lists are designed to minimize waste, ensuring you get the most out of every sheet of wood.
  2. Time Efficiency: No more manual measurements or guesswork. The cut list provides detailed guidance, speeding up the manufacturing process.
  3. Error Reduction: With precise measurements and clear instructions, the chances of mistakes are significantly minimized.
  4. Flexibility: Whether you're working on a large-scale project or a one-off piece, the cut list can be tailored to suit your specific needs.
Embracing the Best of Both Worlds
Incorporating cut lists for saws into Easel Cabinetmaker showcases Inventables' commitment to supporting all cabinetmakers, irrespective of the tools they use. It's a nod to the timeless techniques of the past while embracing the innovations of the present.
The world of cabinetmaking is vast and diverse. Whether you're a fan of cutting-edge CNC machines or cherish the charm of traditional saws, there's a place for every tool and technique. With Easel Cabinetmaker's latest feature, the two worlds come together, promising precision, efficiency, and exceptional results for all.
Consider Easel Cabinetmaker for its ease of use, comprehensive features, and continuous commitment to improvement.
Back to blog
