45 minutes
Using a 3mm aluminum bit mill the two plates that make up the finder tool.
V-carve the lines using a 90dg bit.
Feed rate 250mm/min; Plunge rate 100mm/min; Depth Increment 0.5mm.
Use e.g. ethanol as coolant.
With a M4 bit, thread the holes in the square plate
Using 6 M4x8 or 10 screws assemble the tool. Secure good alignment of edges and the big hole.
Using a 2.5mm drill bit make the two holes on the edges where the V-carved lines meet up. Make M3 thread. Mount M3x10 screws
Now the tool is ready for use
Probe using the G38.2 command
Z: G38.2 z-15 f20
(probe 15mm down using speed 20mm/min)
X: G38.2 x15 f20
(probe 15mm right using speed 20mm/min)
Y: G38.2 Y15 f20
Set position after each probing operation
Z: G92 Z6
(z is 6mm above surface)
X: G92 X-13.5
(x is 13.5mm to the right (12+1.5mm))
Y: G92 Y-13.5
(y is 13.5mm up (12+1.5mm))
Frank Graffagnino
Kyle rock
Yasser Al Khateeb
Martin Barfoed
Tom Brennan
Jawad Saadi
Martin Barfoed
Martin Barfoed
Jamal Alabbood
Martin Barfoed
George Biskitjoglou
Martin Barfoed
George Biskitjoglou
George Biskitjoglou
Martin Barfoed
George Biskitjoglou
Martin Barfoed
Stephen cavanaugh
Martin Barfoed
Orvin mike renfro
