Support closed Sunday 4/2
X-Carve Replica Whiskey Holder
129 opens
45 copies
Julio Reyes
Julio Reyes
Illinois
This my simple version of my design for a liquor/ whiskey bottle & glass set holder. This was my first Easel project and designing it was a blast. I wanted to capture the shape of the X-Carve with side board to hold glass, the bottle as the spindle, and the base as MDF waste board. All under 60 min.
MDF Wood
MDF Wood
Dimensions: 12 in × 24 in, Thickness: 1/2 in
$10.00
Soft Maple - Hardwood Type
Soft Maple - Hardwood Type (×4)
$10.00
Step-1 Carve Side Panels (Mini CNC Maker Slides)
12 minutes
You will need to run this program twice (both sides of Mini CNC) & place aside for later assembly
Step-2 Carve Bottom Panel (Gantry Bottom)
7 minutes
Depending on what bottle you plan to use this will be per your modification. I designed mine to fit a 750 ml square Jack Daniels bottle.
Step-3 Carve Top Panel (Gantry Top)
Again here depending on what bottle you plan to use here is your place for modifying the opening to hold the bottle. Mine is square
Step-4 Carve Bottom Base (Mini CNC Waste + Side Board)
19 minutes
This is where you can really make it yours. I engraved just the X-Carve name where the spindle (bottle) would carve into the waste board.
Step-5 Assembly
11 minutes
I’m going to say this will take about 11 minutes so total time will be at 59min. Sand and smooth all parts paint as desired I would paint my side rails black to match X-Carve and clear coat MDF to prevent any water damage. Place all parts together with glue/screws.
Step-6 Enjoy!
Most important is to enjoy the in between time of carving.
AHHHH last 1 min sip to complete this build for Inventables 60 min power hour challenge.
Please Drink Responsibly :)
