The author’s moral rights;
What program did you use to get the topographic map? I'm having trouble finding one for a school project.
Mattison Donaldson
The map itself I downloaded as a PDF file from the University of Texas (http://legacy.lib.utexas.edu/maps/topo/texas/).
I then used an online converter to go from PDF to DXF.
I then used autocad to cleanup and extract the curves I wanted to use.
Then I imported the DXFs directly into easel.
Fernando Romero
Mattison Donaldson
Fernando Romero
