The Slim Chair from Open Desk
1073 opens
362 copies
8 comments
Nate Fanaro
Nate Fanaro
Smallish chair that can be made with xcarve. https://www.opendesk.cc/regaliz/slim-chair
Carve #1 & #2
Use 3/4 plywood and a 1/4 bit. One chair is split up in to two files.
Assemble
You should have holes where screws will go. I forget what kind I used. Probably 1-1/4 to 1-1/2 inch screws will work. Use woodglue as well.
Justin Haugens
What was your process to port the design files over to Easel? I love Open Desk and have even considered joining a local maker space to carve up some items since they have a 4'x8' ShopBot!
Justin Haugens
Nate Fanaro
It has been a while since I've done this. I think I imported the files from Open Desk in to inkscape, saved that as an svg, then imported it in to Easel. Some adjustments had to be made to be sure I scaled everything correctly.
Nate Fanaro
Ashton Cheek
give instructions
Ashton Cheek
Nate Fanaro
Ashton, added. Thanks!
Nate Fanaro
David Peterson
When opening in Easel, there are missing pieces.
David Peterson
David Peterson
Found them.
David Peterson
Manuel Noailles
la hice, pero quedó muy fragil el respaldo
Manuel Noailles
Nate Fanaro
Manuel, I have noticed the same issue and should have mentioned it. Leaning back in this chair is not the greatest. You may hear some cracking or it could break. This may be better with other kinds of plywood.
Nate Fanaro
