Stitched Plywood Icosahedron Holiday Ornament
91 opens
29 copies
3 comments
Nick
Nick
Taylor, MI
A very cool and modern 20 sided Icosahedron shape, also known as the D20 in some circles. I made it by stitching together plywood cut triangles.
Birch Plywood
Birch Plywood
Choose a Method
Make it with an X-Carve or with WoodWorking Tools. You decide, like a choose your own adventure!
If you are using the X-Carve simply scale the Stitched Wood Icosahedron up or down to fit your needs. A few of the Ideas I had were christmas tree topper, hanging holiday ornaments, bowl, basket, pet cave, lamp shade, lamp base, decorative vase.
Disclaimer: I designed an easel project for making the triangles with all those holes, BUT I didn’t make it on the X Carve…..yet. My 1000mm X Carve is built, but I have no motion controller because I am waiting for the X Controller. My wife and I really wanted to see how it would come together, so I decided to use my table saw and drill press to make her one. After drilling 900 holes in 20 triangles, I learned that the next one will have to made with the X Carve when I get my X Controller.
For this project I used 1/4" BC plywood, but any 1/4" sheet material should be fine.
Use an X-Carve
45 minutes
NO X-Carve: go to STEP 3 Table Saw
YES X-Carve: Cut out the 20 Triangles complete with 45 holes. Then skip to STEP 7 Sand it Smooth
Table Saw
2 minutes
I used my table saw to rip lengths of 1/4" BC Sanded Plywood down to 6" wide strips.
Miter Saw
I set up the miter saw to cut 60 degree angles, I also attached a stop block. This set-up allows me to make a cut, flip the board over, cut, flip, cut, flip, cut… you get the point. What you left with is a bunch of triangles. You will need 20 in total for a full Icosahedron.
Drill Press, Drill 900 Holes!
First off you will need to mark locations for the drill holes. Each triangle has 15 holes on each of its sides for a total of 45. These holes are spaced 3/8" apart, and sit 1/4"oc from the edge of the triangle. Then I set up my drill Press with a 5/16" Drill Bit. Set the Fence and started drilling.
…nine hundred holes…
Drill Press, Drum Sander
I switched out my drill bit for my drill press drum sander. I used a metal washer and traced a curve to round out the pointy triangle, angles. Then with the drum sander I rounded them out by following the line I had just traced.
Sand it Smooth
I took my sanding block and sanded the edges smooth.
Stitch it Up
120 minutes
I used paracord to stitch this Icosahedron together, but you can use anything of similar diameter. Bailing twine or Zip-Ties could be cool. I melted the ends of the paracord. For one end I melted it and pulled it into a point, this allows me to thread it in the holes really easily. The other the I melted into a mushroom shape with helps it hold inside a hole, good for keeping the ends of the rope in place. There are no rules for the style of stitch you use, so go nuts.
9
You Did It!
By this point you should have a finished Icosahedron, and you are probably thinking:
X Carve User: That was fun, I should make another!
Woodworker: …ninehundred holes… never again! Gotta get an X Carve!
Happy Holidays!
Andrew Dewoody
Aren't there 900 holes? After all, 20 x 45 = 900.
Andrew Dewoody
Jay DaMan
NICE.. a "truncated icosahedron" is known as a "classic soccer ball." May have to "fork" your idea to make one for my kids (they play soccer - one fore her HS and one for her college!)
Jay DaMan
Nick
@Andrew Dewoody Oh jeez, you are right! Just updated the project, thanks.
Nick
