Mon - Fri: 9am - 5pm CT
Sunday: 12pm - 4pm CT
Support: 312-775-7009
Standard 3 Wheel MakerSlide Carriage
Bart Dring
Bart Dring from Inventables
This is a project to show the basic items needed to make a standard 3 wheel MakerSlide carriage. It includes some MakerSlide for reference. You should determine if the piece chosen is right for you. You can edit your cart at any time after adding.
Aluminum Spacers - #12, 5M
$2.99
Button Head Cap Screw
Length: 30mm, Pitch: 0.8mm, Quantity: 10, Thread Size: M5
Dual Bearing V-Wheel Kit
Dual Bearing V-Wheel Kit (×3)
Type: Wheels dont use 1, Qty: 1 dont use 1
Eccentric Spacer
Eccentric Spacer
Spacer Type: Standard, Qty: 1 don't use, Length: 0.25 in
Hex Nuts
Hex Nuts
Length: 1000mm - 2012 - 2019
Standard Wheel Carriage Plate
Type: Plate
$4.49
$7.48
b30039.stp
CAD File (STEP)
Assemble the wheels
Press a bearing into one side to the wheel. Place the shim washer on the bearing and press the second bearing into the wheel. The bearing can be pressed in by hand by pushing against a firm flat surface. Make sure the bearings are going in straight. You can use a 5mm screw to make sure the washer stays centered. If the washer moves it is easy to re-center it later with a thin item like a paper clip.
Install the fixed wheels
The wheels are installed on 3 holes in the corners of the plate. 2 holes of about 5.1mm diameter are used for fixed wheels. The carriage plate is not symmetrical, so look for the side of the plate that has the 2 smaller holes in the corners.
Install adjustable wheel
Place a mark on the eccentric spacer on the surface nearest the center hole. This will give you a reference for adjusting later. Install the spacer with the marks facing the outside of the carriage. This will start with the wheels in their widest position. Install the wheel in the larger diameter hole on the other side of the carriage from the fix wheels.
When you put the completed carriage on the MakerSlide adjust the wheels so they just light contact the rail. Excessive tightening will damage the wheels and put a flat spot on them
