spraypaint rack
304 opens
153 copies
7 comments
Zach baker
Zach baker
aresol/spray paint rack made out of .5’/12mm plywood entire project takes 24″×48″ piece i got the file from a FB group didn’t like it so designed this one its not a stolen file its free to you and as i tweak it i will update this file as i know its not perfect the back slots are for 1×4 bracing
Zach baker
picture is the only one i had on hand not finished product and just happened to be from when i was test fitting wasnt
Zach baker
Michael Hicks
I really like this idea. Just a question for you, did you cut it out using the cut settings in the custom settings, if so did you have trouble with bits breaking and what brand of bit did you use?
Michael Hicks
Zach baker
i believe they were hq master compression bits I didn't have any trouble with bits breaking while running custom settings
Zach baker
Luis Taveras
HQ Master Compression Bits. Best and fast for ply.
Luis Taveras
Richard Risch
How does this attach to the wall? I see the grooves cut in the back, but curious if they're functional
Richard Risch
Zach baker
it was intend for 1x stock to brace it and hang it on the wall
Zach baker
Tad Seaton
I see you say 24"x 28" of plywood .5" how many pieces of wood i see 4 cuts
Tad Seaton
