Curtis Dorrington
This ramp is designed to be carried with the user who may need access requirements where it might not be otherwise be possible.
This is a first draft.
Example of use: hung on the side of a wheel chair and drop in front of a doorway to enter, the hook is then used to pick the ramp back up.
