Nine Men Morris
52 opens
24 copies
Jeffrey Leegon
Jeffrey Leegon
A simple Nine Men’s Morris board. It is a 2-player game that has been played since Roman times. More information on Wikipedia:
http://bit.ly/2dFCiGt
Red Oak Plywood
Red Oak Plywood
Stain Plywood (Optional)
I sanded the plywood to 220 grit. I then used a dark Danish oil to darken the plywood so the lines would be a bit more visible. Follow the directions on the can.
Cut the board out
47 minutes
This could be sped up by making the lines shallower. The depth currently in the file at isn’t really necessary. 1/8 would be plenty. This was one of my first projects I did on the X-carve. After having more experience I would suggest .1 inch depth should be plenty for making the lines.
Play the Game
Grab some checker pieces or something similar and then play the game.
You can find history and rules here: http://bit.ly/2dFCiGt
