Monogram Pumpkin
934 opens
461 copies
5 comments
Rusty
Rusty
Fun Halloween decoration to put on your front step or hang on your door!
MDF Wood
MDF Wood
Cut
“Trick or treat” was cut using a 1/16" upcut end mill and the “Pumpkin” cut using an 1/8" single flute upcut endmill. The parameters were as follows:
Improvement – My tabs were a bit thin and ended up breaking loose during cutting! I would make those tabs a bit stronger!
Primer
Primed with white primer. You can skip this about go straight the paint paint, but using primer and sanding once dry will give you project a smoother finish and vibrant colours!
FINISH!
Pick your favourite colour and get painting! I used Krylon Pumpkin Orange spray paint and it turned out great!
Patrick Brown
Can you share the project publicly?
Patrick Brown
Rusty
Sorry about that! It should be good to go now!
Rusty
John Gifford
Awesome decoration, thanks for sharing!!
John Gifford
Wil Pineda
I can't figure out how to combine and trim the text with the circle like that. Did you use easel?
Wil Pineda
Geomotiv
<a href="https://geomotiv.com/services/custom-software-development/">custom software development los angeles</a>
Geomotiv
