An alternative top for my “Struggle Stick” Easel Power Hour fight stick. You can’t use this without a shell for it, or can…I don’t know your life.
This project requires a Pro Easel account as well a 90 degree V Carve bit.
Without it you won’t get the detailed Shodan carve. 8 Button Sega layout.
No Derivative Works — You may not alter, transform, or build upon this work.
The author’s moral rights;
Directions are in Easel notes. 30mm short barrel buttons (I suggest something like seimitsu-PS14GN or similar). Also a 24mm button same specs. Have fun.
Looks great! Would you be willing to make the project public?
Teresa Jo Parsons
Teresa Jo Parsons
