Full Height Version of "DIRESTA Wood Stool "
110 opens
38 copies
457 downloads 0 comments
Tim Belcher
Tim Belcher
Well, we bought a big x-carve… lets make a big stool. This version is a 29.5 inch tall bar stool. It uses almost the entire 31 × 31 inch space of the large x-carve. I also am including the g-code for a DIRESTA vcarve, removing any need to fix the A.
Diresta Stool 2 Logo.nc
Watch the Diresta Video
This is designed for 3/4 inch stock, and includes a gcode file for the DIRESTA logo using a v-carve, therefore you will not need to fix the A. (It also looks a lot better).
Be careful with this, as a large portion of the sheet is used. I increased the tab height to .2 inches, given so much of the sheet could come loose. I start with an oversized 32 × 32 inch sheet and use double sided tape. I then move my X and Y as close to the bottom left as I can. This entire design will fit into a 30×30 however.
Cheers,
Tim
