A small dice box. Holds about 18 dice or 9 dice and a pen its up to you.
Use a .75inch end mill for the large dig outs and a 1/8 up cut bit to cut it out
The author’s moral rights;
something seems to be wrong with the file so that it is unable to "open in easel". I'm new but this was the first thing I tried to open and it repeatedly failed. After 5 or 6 tries I attempted a different dice box and that one opened just fine.
Dove Dunham
Dove Dunham
Baron Black
Nicholas Fisher
