Tools:
Fishtail Milling Bits: 1/16" and 1/32" will allow you to make very detailed stamps.
Saw: Some form of saw for cutting the stamp out after you’ve carved them. This can be done with the x-carve but I would recommend changing bits before you carve through all that material.
Brush: If using acrylic paints.
Materials:
Mounted Linoleum
Craft Paint or Stamp Pad
Something to Stamp!
3 minutes
Add a shape element that fully encompasses the size of your design or the total size you would like the stamp to be.
Next you’ll need to select and send this shape to the furthest back layer possible by using the menu system: Edit; Send Backward, or you can use keyboard shortcuts: cmmd + [
Now comes the really fun part, Stamping! There are several different brands and colors of stamp pads out on the market. I tried using pigment stamp pads but was a little unimpressed with the final result so I decided to give Acrylic craft paints a try and was far more pleased with the results as well as how many different sub straights it transfers to.
Zach Kaplan
Travis Lucia
Matthew Nuss
Bewilderbeast Brandon
MeischanParrilla
