Support closed Sunday 4/2
Circuit Board Milling Starter Kit
Michael Una
Michael Una from Inventables
Chicago, USA
I added two types of circuit board material- we carry both 2×3″ and 4×6″ in single-sided and double-sided varieties.
Milling 2-sided circuit boards is easy if you design with milling in mind, and prepare your work surface- plane a rectangle slightly larger than your board.
Circuit Board Blanks
Dimensions: 2 sided FR1 circuit board stock 4 in × 6 in (25 pack)
Dimensions: 2 sided FR1 circuit board stock 2 in × 3 in (25 pack)
PCB Drill Set
PCB Drill Set
Qty: 10 Sizes, Material: Tungsten Carbide
$20.99
PCB Milling Bits
PCB Milling Bits
Quantity: 10 (Do not use), Shank Diameter: 1/8 in (Do not use), Cutting Diameter: 0.004 in - 0.008 in (Do not use)
$20.99
Protip: Mill a pocket
Make your life easier: mill a shallow pocket into your wasteboard slightly larger than your circuit board. It’ll help you position and clamp/tape your board in place and keep it square to the machine.
Give yourself a registration mark
If you’re going to be doing multiple separate toolpaths, such as a drill before a trace routing, you need to give yourself a registration mark to keep everything in the right place. I manually plunge the drill bit into my 0,0 spot before running the first operation to give myself an easy way to keep track of it.
For a two-sided board, consider putting a drill hole at your 0,0 and also at a symmetric location on the right edge of the board, so it’s in the same place when you flip the board over.
Go slow!
A good starting point for your cutting speed is 10 inches/min. And you shouldn’t need to cut deeper than ~.015" to get good clean traces. At that speed you should be able to do it in a single pass.
Dean Melillo
I had trouble with pcb gcode come with eagle seem not right to me. How do it run smooth? Every time I noticed the pcb board looked like some deep but the wire is small and some not deep but the wire is not small. I had some frustrate with pcb gcode and eagle (drc). Please let me know. Thanks.
Dean Melillo
