This project includes the SVGs for a 1000mm wasteboard, 90º alignment rails, and jig, as well as cam clamps. The wasteboard includes layout lines for 6", 12", 18", and 24" stock sizes. The wasteboard has 15/32" holes for 1/4-20 threaded inserts.
The author’s moral rights;
