X-Carve: In Stock. Ships in 1-2 business days. Learn More
312-775-7009 | help@inventables.com
Mon - Fri: 9am - 5pm CT
Sun 12pm – 4pm CT
X-Carve
From $1892.0 or Affirm white
X-CARVE + Easel
Design.
Carve. Sell.
Design. Carve. Sell.
Speed up your startup with our best-selling bundle — the fully loaded machine and easy-to-use software.
Description section2
Easy. Affordable. Compact.
No CNC knowledge required. X-CARVE and EASEL simplify 3-D design so you can carve wood, plastics and other materials in minutes.
Power your business with X-Carve
Quit your day job and launch your dream job with the world's easiest, most affordable desktop CNC machine. These X-Carve owners share how they started a business with X-Carve, Easel and Easel PRO.
Free Support
Our US-Based Customer Success team is available to help before and after you buy your X-Carve. Call or email a real human with your questions, comments, and concerns.
Save Time
Quickly prototype a new idea or iterate on the spot to improve an existing design. When you are ready to sell, the X-Carve's durable rails, robust X-Controller, and reliable stepper motors enable you to scale production.
Repeatability
Our free software, Easel, makes it easy to fulfill order demands. Customize your designs and rapidly carve products in batches - precise accuracy.
WORLD’S EASIEST CAD/CAM SOFTWARE
Computer desktop 2x
3 YEARS OF EASEL PRO
WITH EVERY X-CARVE
Better together
Our best-selling CNC machine works best when paired with EASEL, the world’s easiest CAD/CAM software. That’s why a 3-year EASEL PRO subscription is included with every purchase. It’s the only software your business needs to design, import, carve, and share—all in minutes!
Computer desktop 2x
“At HomeMade Modern, added reliability lets me carve whatever I can draw, building things larger and more complex than I was previously capable of.”
Ben Uyeda
Designer, HomeMade Modern, Boston
Benuyeda headshot
Dimensions
Work Area
1000mm rails
X-axis: 750mm
Y-axis: 750mm
Z-axis: 65mm
Machine Footprint
1000mm rails
X-axis: 1250mm
Y-axis: 1000mm
Z-axis: 350mm
Accuracy
A properly tuned and calibrated machine should get to a resolution of ~0.075mm to 0.13mm.
Electronics
X-Controller with Grbl Installed (USB)
Input voltage: 115VAC or 230VAC (selectable)
Spindle
Model: DeWalt 611
Amps: 7.0Amps
Horsepower: 1-1/4HP
No load speed: 16,000-27,000rpm
Rapid rate
Recommended defaults:
X-axis: 8000 mm/min
Y-axis: 8000 mm/min
Z-axis: 500 mm/min
