Mon - Fri: 9am - 5pm CT
Sun: 12pm - 4pm CT
Support: 312-775-7009
X-Carve Upgrade: Z Axis Kit
Upgrade the rigidity, precision, and add 2" of gantry clearance of your X-Carve
  • X-Carve Upgrade: Z Axis Kit
Price Part Number Contents
$360.00 Direct Drive Z-Axis, 2" Risers, and Stiffeners
Upgrade the rigidity, precision, and gantry clearance of your X-Carve with Z-axis and height improvements in this kit. With an additional 2 inches of Z-axis travel, this kit will nearly double the carvable volume of your X-Carve.
  • Direct drive configuration eliminates drive belt and improves accuracy and reliability
  • Reduce adjustments and maintenance
  • Increases gantry clearance from 2.5” to 4.5”
  • Increases maximum pass-through sheet width from 34.75” to 37”.
  • Unique shape prevents potential interference with dust boot when machine is at XY home
  • Keeps shavings within the work area of the machine
NOTE: X-Carve Machines purchased 2015 or earlier will need updated Z stepper motor cable assembly.
The full NEMA 23 Cable Subassembly can also be purchased.
Includes
Direct Drive Z-Axis with upgraded 212 oz-in stepper motor (+50% torque)
2" Risers (4)
Acrylic Dust Guards / Stiffeners (8)
Installation Time
Installation Instructions
Available here
Add your project
FAQ
How difficult is it to install this kit?
It’s quite simple, actually, and shouldn’t take longer than an hour with our easy-to-understand instructions.
What if I also want the Belt Upgrade Kit?
Great! You’ll maximize the performance gains AND you can save money by purchasing both together in our Ultimate X-Carve Upgrade Kit.
What is the height of the machine with the upgraded Z-axis included?
The overall height is 21 1/4".
Will the upgrade kit work with pre-2016 X-Carve Kits?
To get the most out of this upgrade, we highly recommend using the X-Controller Kit and the Wide Makerslide.. While the new stepper motors can be run on the original g-shield controller, you will not be getting the full benefit from the upgraded motors.
