Make your X-Carve stronger, smarter, and more reliable with this upgrade kit. Backwards-compatible with all X-Carve machines shipped before September 2016.
The X-Carve upgrade kit is available in both 500mm and 1000mm sizes.
Each kit contains:
The stepper motor cable is included in case you would like to take advantage of the X-Controller’s extra stepper driver. That part of the upgrade process is a “nice to have” option, not a necessity. If you don’t need to use the extra driver, just ignore the stepper motor cable. More information about rewiring the machine to use all four stepper drivers is available at the X-Controller Usage Instructions under “Option 2.”
NOTE: A 500mm machine cannot be upgraded to a 1000mm machine without additional parts.
