X-Carve NEMA 23 Upgrade
Upgrade 2015 X-Carve to 2016 motors and cable assemblies
Price Part Number Description Machine Size
$202.96 4 motors + 4 cable assemblies 500mm
$202.96 4 motors + 4 cable assemblies 750mm
$203.46 4 motors + 4 cable assemblies 1000mm
These motors run the three axes on your machine. The pulleys come attached, and snap-in wiring makes it easy to set up your machine.
Click here for 500mm assembly instructions
Click here for 750mm assembly instructions
Click here for 1000mm assembly instructions
The above links take you to the section of the X-Carve instructions in which the stepper motor components are first mentioned, attaching to the side plates. Subsequent homing switch installation steps are found in the X-Carriage, Z-Axis, Belting and Wiring sections.
Add your project
