X-Carve Homing Switch Upgrade
Hardware to update 2015 X-Carve to 2016 homing switches
Price Part Number Machine Size
$26.75 500mm
$24.75 750mm
$26.25 1000mm
Using this set of three switches, you can home to the same starting point every time. The kit comes with enough wire for your X-Carve size.
Click here for 500mm assembly instructions
Click here for 750mm assembly instructions
Click here for 1000mm assembly instructions
The above links take you to the section of the X-Carve instructions in which the homing switch components are first mentioned, attaching to the side plates. Subsequent homing switch installation steps are found in the X-Carriage, Z-Axis, Rails and Wiring sections.
Contents
3 homing switches, 3 cable assemblies + mounting hardware
Add your project
