Ever experience your eccentric nuts loosen and fall off of your 2015 X-Carve? This upgrade pack replaces those eccentric nuts with our new eccentric spacers and includes all of the necessary hardware to make the switch. Now with the spacers and nylon insert lock nuts, you should no longer experience hardware falling off of your machine.
This kit contains:
Qty | Product | Dimensions |
8 | Eccentric Spacer | 0.20 in |
2 | Eccentric Spacer | 0.375 in |
2 | Aluminum Spacers | 5.1mm ID 9.5mm OD 9.5mm LG |
4 | Button Head Cap Screw | M5 x 40mm |
8 | Button Head Cap Screw | M5 x 30mm |
12 | Nylon Insert Lock Nut | M5 |
For those needing help with installation, refer to the latest X-Carve instructions here:
