X-Carve Drag Chain Upgrade
Parts to upgrade 2015 X-Carve to 2016 drag chain
Price Part Number Desciption Machine Size
$57.36 2 drag chains + supports and mounting hardware 500 mm
$66.55 2 drag chains + supports and mounting hardware 750mm
$77.24 2 drag chains + supports and mounting hardware 1000mm
This plastic chain is designed to organize and protect your wiring as the machine moves. The chain is comprised of individual links that swivel in one direction. An open-close feature running the length of the chain makes organizing and accessing wires easier than ever.
Click here for 500mm assembly instructions
Click here for 750mm assembly instructions
Click here for 1000mm assembly instructions
The above links take you to the section of the X-Carve instructions in which the drag chain components are first mentioned, attaching to the side plates. Subsequent drag chain installation steps are found in the X-Carriage, Assemble Gantry and Wiring sections.
2015 X-Carve Gantry Side Plates will not work with this upgrade, as they are missing the hole pattern to attach the drag chain brackets. The latest version of the Gantry Side Plates can be found here.
Add your project
