X-Carve Drag Chain Kit
Parts to upgrade X-Carve to 2016 drag chain
Price Part Number Description Machine Size
$49.00 2 drag chains + supports and mounting hardware 750mm
$59.00 2 drag chains + supports and mounting hardware for X-Carve 1000mm
This plastic chain is designed to organize and protect your wiring as X-Carve moves. The chain is comprised of individual links that swivel in one direction. Individual links can be open and closed, making wire organize and access easy—even after your X-Carve is assembled.
Includes:
• Two (2) drag chains (one for Y-axis, one for X-axis)
• Support extrusions
• Mounting and assembly hardware
PLEASE NOTE
2015 X-Carve Gantry Side Plates and X-Carriage will not work with
this upgrade, as they are missing the hole pattern to attach the drag chain
brackets. In order to use this upgrade kit, you will need to upgrade to the following versions of these items:
-Gantry Side Plates
-X Carriage
Note that the latest version of the X Carriage also lacks the mounting holes for the terminal blocks as the latest version of the X-Carve includes connectorized motors. You’ll need to find an alternative way to wire the stepper motors or attach the terminal blocks.
Step 1 (1000mm):
1000mm assembly instructions
Step 1 (750mm):
750mm assembly instructions
Step 1 (500mm):
500mm assembly instructions
Step 2 (all sizes):
X-Carriage
Step 3 (all sizes):
Assemble Gantry
Step 4 (all sizes):
Wiring
Files & Attachments
2015 X-Carve Drag Chain Information
Drag_Chain__2015_X-Carve_Information.pdf
Add your project
