X-Carve in stock. Ships same business day. Call us: (312) 775-7009
(M-F 9am - 5pm CST)
X-Carve 750mm Waste Board Kit
An upgraded waste board with support for clamping.
  • X-Carve 750mm Waste Board Kit
Price Part Number Description Machine Size
$99.00 Waste board with threaded inserts and hardware (clamps not included) 750mm
This is a waste board for X-Carve that has the following features.
  • Pre-drilled and counterbored holes for M5 threaded inserts to attach clamps
  • Silkscreen pattern to show the general work area of the machine
  • Easy installation by sliding in from the side without having to disassemble the machine
  • Extra mounting holes in the middle of the board in case you want add (2) cross members for additional support.
  • Works great with our Clamp Set for 3D Carving
  • Mounting hardware and threaded inserts included
Assembly Required
There is some final fabrication required by the end user for this product to function. The inserts need to be installed. We have instructions that demonstrate how to do this. Please note the inserts go in from the back side.
Boards have provisions for adding additional cross members underneath for support. This is strongly recommended for the large version or it will sag over time.
Note
The material is MDF. There may be small scratches, discoloration or scratches on the surface that do not affect performance.
Additional Sizes
Add your project
