USB Motion Controller
Control a 6 axis CNC machine over USB
  • USB Motion Controller
Price Part Number Type
$129.00 USB Motion Controller UC100
The UC100 is a USB motion controller for Mach3. Traditionally, Mach3 used a parallel port to control your machine. Parallel ports are rare these days and Mach3 does not support Windows 7, 8 or 8.1. You cannot use standard USB to parallel port converters with Mach3. This product solves that problem.
Specifications
  • Motion Control of up to 6 axes (X,Y,Z,A,B,C)
  • Configurable step frequency up to 100kHz
  • 100% parallel port compatible pinout
  • Pullup resistors on all inputs
  • Automatic firmware checking and upgrade
Features
  • Supported Mach3 functions:
    • Jog.
    • Reference inputs.
  • E-stop input.
    • Softlimits.
    • Limit switch inputs.
    • Limits override.
    • Index input (extended function supports multi slot spindle sensors,
  • Mach3-mill only feature, (not Mach3 Lathe).
    • Spindle speed PWM control output.
    • Step and direction spindle control output.
    • Spindle and coolant relay control.
    • Charge pump safety signal output (configurable to active/inactive when in E-stop).
    • Charge pump adjustable frequency (12.50kHz in normal or 5kHz in laser mode).
    • All signals configurable to active High/Low.
    • General purpose I/O signals handling.
    • Offline mode.
    • All MPGs and encoders support (2pcs maximum one time).
    • Slave axis.
    • Backlash compensation.
    • Digitizing probe input.
    • Plasma torch height control inputs.
Add your project
