UP Mini 3D Printer
On clearance! $479 (reg. $599)
UP Mini 3D Printer
  • UP Mini 3D Printer
  • Play
  • Play
  • Play
  • Play
  • Play
Price Part Number
$479.00
LIMITED QUANTITIES AVAILABLE. Please call (312) 775-7009 for availability. You will be refunded if we oversell and cannot fulfill your order.
The Up! Mini 3D printer is a desktop printer that is as easy to use as a traditional inkjet. You simply plug it into your computer, install the included software, and start printing! This is not a kit, it’s a fully functional, pre-assembled 3D printer in a stylish black matte/glass case, with a fully enclosed build area. The printer is quiet, and looks quite nice as a desktop accessory with no ungainly wire wraps, and a clean professional exterior look.
There is no sacrifice on build quality with the UP! Mini, with its enclosed steel construction, double linear bearings on each axis and a temperature stabilizing build chamber.
Build Footprint
120 × 120 × 120mm
Build Platform
Enclosed to reduce warping
Print Speed
10-100cm^3 per hour
Layer Resolution
250 microns
Accessories
View More
Add Your Project
FAQ
What software is the UP Mini compatible with?
The UP Mini requires the latest version of the UP Software.
