Free shipping on non-machine orders of $100 or more within continental US
Uneven surface sealing tape
On clearance! $5 (reg. $12.50)
Price Part Number Type Tape Type Length
$5.00 Tape Sealing 1 yard
Uneven surface sealing tape is designed for difficult sealing applications. The backing on the tape is very tough yet flexible and resistant to abrasion. It can be used outdoors in situations where it will be required to adhere over the long term. The tape was designed to seal over joints or seams and can be painted after applied.
This tape replaces caulks or sealants in a easy to use single sided tape form that will bond to many metals and plastics without the drying time, dripping, oozing, or cleanup required with traditional sealants. The tape conforms over contours, edges, rivets and screw heads for a water tight seal. The tapes outer ionomer layer can be painted to blend in with adjoining surfaces.
Density
51 lb/ft 3 (0.82 g/cm3 )
Tensile Strength
13.4 lbs/in tape width (23.5 N/cm tape width)
Elongation to Break
380%
90 Degree Peel Adhesion
9.9 lb/in tape width (15.7 N/cm tape width)
Splice Break Strength
10 lb/1 in. × 2 in. tape (17.5 N/25 mm x 100 mm tape)
Max Temperature Tolerance
Short term (minutes, hours) 300°F (149°C) Long term (days, weeks) 200°F (93°C)
Slitting Tolerance
± 1/32" (0.8 mm)
Thickness Tolerance
± 0.008" (0.2 mm)
Files & Attachments
Datasheet
Uneven Surface Sealing Tape spec sheet.pdf
Add your project
