Two-Color HDPE - White on Blue
Textured sheet with layers of contrasting colors ideal for engraving
  • Two-Color HDPE - White on Blue
Price Part Number Thickness Dimensions Quantity
$9.71 1/4 in 12 in × 12 in 1
$20.89 1/4 in 12 in × 24 in 1
$6.49 1/4 in 8 in × 12 in 1
This King ColorCore® unique 3 layer high-density polyethylene sheet is perfect for engraving. A layer of blue HDPE is sandwiched between two 0.050″ layers of white, making it easy to expose different colors while engraving or milling.
This material is strong and environmentally stabilized, meaning it can withstand harsh weather conditions. This makes it great for sign-making, marine applications, recreational equipment, etc.
The sheets are masked on one side. The other side may have minor scratches or scuffs.
Top and Bottom Layer Thickness – 0.050"
Density (ASTM D1505)
0.96 g/cc
Tensile strength at yield (ASTM D638)
> 4100 psi
Tensile modulus (ASTM D638)
225,000 psi
Elongation at yield (ASTM D638)
9.8%
Elongation at break – % (ASTM D638)
600
Flexural modulus (ASTM D790)
185,000 psi
Heat deflection temp. 66 – psi (ASTM D648)
167° F
Screw and nail withdrawal (ASTM D1761)
657 lbs and 63 lbs
Cut tolerance
+/- 1/8"
Color
Blue
Color
White
Surface Finish
Textured
Type
Two-color engravable
Files & Attachments
MSDS
Two-Color HDPE MSDS.pdf
