Solid State Relay
Switch high voltage, high current AC devices with your controller
Solid State Relay
Price Part Number Type Current
$15.25 Solid State Relay with Heatsink 25A
This solid state relay allows you to control high current AC equipment with a low voltage signal that would come from a micro controller, like an Arduino or a CNC controller like a gShield or TinyG.
Warning: You need to wire dangerous AC voltage to this device. Only experienced electrical technicians should do this.
Files & Attachments
Datasheet (PDF)
ssr25da.pdf
Accessories
Add your project
