Special Offer: Up to 25% off the new X-Carve Pro
Hurry! Offer ends on 03/31 (31 days left)
Call us: (312) 775-7009
Email: help@inventables.com
Mon - Fri: 9am - 5pm CST
Solid Carbide Single Flute Upcut End Mill
Ideal for soft plastics
  • Solid Carbide Single Flute Upcut End Mill
  • Play
Price Part Number Quantity Shank Diameter Cutting Diameter
$4.84 1 1/8 in 1/8 in
$29.99 10 1/8 in 1/8 in
The spiral upcut bits pull chips from the cutting surface upwards, leaving a flat bottomed pocket. This provides accurate cuts without chatter in the plastic because the chips are being evacuated away from the cutting edges. This bit is not recommended for wood because it pulls the wood fibers causing tear out.
Cutting Length
0.87 in
Overall Length
1.77 in
Best for Cutting
Corian, aluminum, plastic, linoleum
Accessories
