Special Offer: Up to 25% off the new X-Carve Pro
Hurry! Offer ends on 03/31 (31 days left)
Call us: (312) 775-7009
Email: help@inventables.com
Mon - Fri: 9am - 5pm CST
Smooth Idler Wheel Kit
Adds an adjustable idler wheel to a linear motion system
  • Smooth Idler Wheel Kit
Price Part Number Qty
$5.99 1
$52.49 10
This is double bearing, Delrin, smooth idler wheel. It uses (2) 5×16×5 bearings and a precision shim washer. This is perfect for adding an adjustable idler wheel to your system. It has very low runout, so it will run wobble free. The mating bracket is very simple with only a 5mm hole required.
The idler wheel diameter does not usually need to match your drive pulley diameter. The belt can run a triangle or more complicated path as long as one side is parallel to the axis you are driving.
Here is a link to the technical drawing for the smooth idler.
Description
Kit includes 1 smooth idler, 2 ball bearings and 1 precision shim washer.
Type
Wheels
Files & Attachments
Technical Drawing
25197-02.pdf
CAD File (STEP)
25197-02.zip
