Purple MDF Sheet
Strong, organically dyed wood fiber panels - On Sale!
Purple MDF Sheet
$7.00 12 in × 12 in 3/8 in
Features
  • 30% stronger than traditional MDF
  • Easy to machine
  • Non-toxic
Valchromat® is a through-color wood fiber panel. Individual fibers are impregnated with organic dye and chemically bonded by resin specially developed to give the panel its special properties. It’s an evolution of MDF and fits somewhere between a wood fiber board and a solid surface, because of the specially formulated resin within the board. It is at least 30% stronger and more stable/resistant than standard MDF board. It is completely moisture resistant, provided the correct finish is applied. Valchromat® increases the life span of tools used in its manufacturing due to a lubricant agent in its composition.
This material is classified E1 (low on formaldehyde) according to European norms. It has been approved by the British standards association as safe to use in the manufacture of children’s toys.
Valchromat® is manufactured from 50-60% recycled raw materials purchased from pallet and furniture manufacturers. All the pine logs used in production come from Portuguese forests, most of which are privately owned and harvested, representing a significant source of income with little investment.
Cut tolerance
+/- 1/16"
Color
Purple
Thickness
3/8 in
Type
MDF
Files & Attachments
Data Sheet
Colored MDF Data Sheet.pdf
