Precision Shim Washer
Prevents binding of bearings
  • Precision Shim Washer
Price Part Number I.D. O.D. Thickness
$0.40 5mm 10mm 1.0mm +/- 0.076
$0.60 $0.36 3mm 5.5mm 1.0mm +/- 0.076
This is a stainless steel shim washer. When using dual bearings, you need a spacer between the inner races, so all compression forces go through the inner races. This prevents binding of the bearings.
Thickness
1.0mm +/- 0.076
Type
Washer
