Powered LED Strip - Yellow
A simple lighting solution for EndLighten acrylic that doesn't require wiring
  • Powered LED Strip - Yellow
  • Play
Price Part Number Length
$23.99 8 in
This is an incredibly easy solution for illuminating your EndLighten (edge-lit) acrylic. The bright LEDs are encased in a chrome-colored plastic housing that slides easily and snugly over the edge of your 1/4" acrylic sheet. Simply plug it into the wall to turn the LEDs on – no wiring required.
The EndLighten acrylic sheet is not included but can be purchased through Inventables.
Power supply (included)
12V/1A
Barrel connector (included)
5.5mm/2.1mm
Total cord length (barrel connector in middle)
12 ft
Color
Yellow
Type
AC Plug
Add your project
