Power Entry Module
Add an AC power connector to your project
Power Entry Module
  • Power Entry Module
Price Part Number Connector Type Mounting Style
$4.99 $2.99 IEC60320, Snap In
$5.49 IEC60320, Bolt Flange
These modules are an easy way to add an AC power connector to your project. They have an integral fuse. The fuse holder also stores a spare fuse (included). There are two styles. One snaps in and the other bolts in. The switch has a light the glows when the power is on.
See the wiring diagram to see how to wire this part.
Connector Type
IEC60320,
Files & Attachments
Datasheet (PDF)
Model AC-5840.pdf
Datasheet (PDF)
Model AC-5028.pdf
Wiring Diagram (JPG)
