Free shipping on orders of $100 or more within contiguous US. Exclusions apply.
PLY90 Corner Brackets
A fast, stylish way to connect sheet materials
  • PLY90 Corner Brackets
Price Part Number Description
$30.00 4 pack of PLY90 brackets
$5.00 Tightening tool (3/16" hex ballpoint driver)
The PLY90 is a patent pending connector that is a faster, better looking alternative to drilling and screwing projects together. Save time and energy by not having to align every board and precisely drill and screw all the pieces together. Easily disassemble creations for storage or moving, and recycle old projects into new ones. The brackets are sold in packs of 4. Use the hex ballpoint driver tool to tighten the brackets.
Each PLY90 bracket includes 2 screws that allow it to work with all sheet materials/plywood between .450"-.755” thick. The connectors will accommodate most commonly available plywood thicknesses. They create a 1" offset from surface to outside edge.
The 3/4" or short screw is for 1/2" materials, the longer 1" screw is for 3/4" materials. The brackets work best when materials of similar thickness are placed in both sides of a connector. PLY90 has wall mounting features (2" long #8 or #10 screws are recommended but not included).
The brackets are made in the USA from high strength aluminum alloy. The aluminum is shaped through a process called extrusion and then the parts are cut, drilled and finished. The hardware is premium alloy steel.
Use these connectors to build:
  • Desks
  • Monitor stands
  • Chairs
  • Tables
  • Shelves
  • Planting boxes
  • Art installations
Add your project
