Plastic MXL Pulley - Dual Flange
Plastic pulley with metal insert and set screw
  • Plastic MXL Pulley - Dual Flange
Price Part Number Bore Teeth
$5.99 5 mm 18
$6.49 .25 in 18
$6.49 .25 in 20
This is a MXL pitch (0.08") plastic pulley with metal insert and set screw. It has dual flanges. There are two choices for bore configuration and two choices for tooth configuration, both configurations have dual flanges, and use a set screw.
Note: These plastic pulleys are not compatible with X-Carve, which is intended to be used with Aluminum GT2 Pulleys
Bore:
Teeth:
  • 18 tooth
  • 20 tooth
Weight
0.1lbs
Type
Dual Flange
Category
Accessory
Type
Pulley
Files & Attachments
CAD File (STEP)
25204-02.zip
CAD File (STEP)
25204-03.zip
CAD File (STEP)
25204-05.zip
