Special Offer: Up to 21% off the new X-Carve Pro
Hurry! Offer ends on 04/30 (11 days left)
Call us: (312) 775-7009
Email: help@inventables.com
Mon - Fri: 9am - 5pm CT
Orange Anodized Aluminum Sheets
Etch designs into aluminum using a laser cutter
Price Part Number Dimensions
$3.99 3 in × 3 in × 0.02 in (24 gauge)
Perfect for Halloween!
Anodizing is a process used to increase the thickness of the natural oxide layer on the surface of metal parts. It increases corrosion and wear resistance, and during the process the anodized aluminum surface can be dyed into many different colors.
The front of each sheet has a pristine finish; the back may contain a slight groove spanning the width of the sheet, or minor blemishes. These imperfections are caused by the manufacturing process and will only be found on one side of the sheet, if at all. Coloration may vary from batch to batch.
Color
Orange
Form
Sheet
Material
Aluminum
Surface Finish
Anodized
Add your project
FAQ
What is the best setting to achieve the white finish when engraving?
15-18 watts power at 100% speed.
