Needle Tip Applicators
Bottles, syringes and replacement tips for applying solvents like Weld-On
  • Needle Tip Applicators
Price Part Number Description Size
$9.99 Bottle with 4 assorted needle tips 2 oz
$6.99 Syringe with 27-gauge metal needle tip 30 cc
$1.99 Funnel for filling bottles Small
$2.99 16-gauge metal replacement needles 3 pack
$7.49 $4.49 20-gauge flexible poly replacement needles 3 pack
$2.99 22-gauge metal replacement needles 3 pack
$2.99 25-gauge metal replacement needles 3 pack
$2.99 27-gauge metal replacement needles 3 pack
These various applicators are great for applying liquid solvents like Weld-On 3.
Remember when choosing a gauge that lower numbers are wider in diameter.
  • 16 gauge needle tips allow the fastest flow and are recommended for larger projects where extreme precision is not necessary
  • 20 gauge flexible poly needle tips are for hard-to-reach spots
  • 22 gauge needle tips are the most common for general fabrication use
  • 25 gauge needle tips are precise while still allowing for decent flow
  • 27 gauge needle tips are for extreme precision and slow flow
The needle tip assortment consists of 1 each of 16-gauge, 25-gauge, and 27-gauge metal needles, and a 20-gauge flexible poly needle.
The funnel makes it easy to pour Weld-On 3 from the can into the applicator bottles.
All replacement needles fit on both the bottle and the syringe.
Type
Applicator
