Lightweight metallized polyester film
On clearance! $34 (reg. $43.60)
Price Part Number Description
$34.00 $20.40 1 linear yard sample that is 42.5 inches wide.
This is a polyester-based fabric that is both tough and light weight. It is only 0.08 mm thick. Its surface resistance is 0.01-0.03 Ohm/sq. Because nickel may produce skin allergies, this material is not intended for direct contact with skin. Protective gloves are recommended when handling this material.
• Width: 1080 mm (42.5 inch)
• Thickness: 0.08 mm (3 mil)
• Weight: 90 g/m²
• Surface Resistivity: 0.03 Ohm/sq
