Hi-Lo Screw
Great for fastening plastics, plywood, and particle board
Hi-Lo Screw
  • Hi-Lo Screw
  • Hi-Lo Screw
  • Hi-Lo Screw
Price Part Number Finish Length Quantity Thread Size
$2.99 Zinc Plated 0.25 in 10 #4-24
$2.00 $1.20 Stainless Steel 0.50 in 10 #4-24
$3.00 Stainless Steel 0.50 in 10 #10-26
$3.00 Stainless Steel 0.75 in 10 #10-26
$3.99 $2.39 Zinc Plated 1.00 in 10 #10-26
Hi-Lo self tapping screws have a double lead thread where one thread is high and the other low for easier penetration into the substrate. The high thread is sharper than a conventional thread. The sharp high thread causes less displacement of material when it is driven into the substrate. Consequently, it requires less effort to drive into material. In addition the greater amount of material remaining in between the high threads, the smaller minor diameter thread increases contact with the substrate resulting in a stronger grip and increased resistance to pull out and vibrational loosening forces.
Quantity
10
Screw Type
Hi-Lo
Type
Screw
